Magicool Slim Profile 2X140mm Radiator - Fitting issue
eTanium
Does anyone have this running in their system? I am looking to buy it for a low to medium (1300rpm) fan speed, and I can't find anything about it's FPI count.
Also, on the site I plan to order it from, it states, "Now with customizable fittings for 3/8" ID and 1/2" ID!"
And then it gives me a choice of which I would like to have sent with the RAD.
Will standard 1/4 fittings this RAD?
What are they speaking of when they say 3/8 and 1/2?
That should have to do with tube thickness, no?
I'm using 1/2" Inner Diameter (12.7 mm), 3/4" Outer Diameter (19.05 mm) tubing with a wall thickness of only 1/8 inch (3.17 mm).
Thanks.
Their website says 14 fpi,
as for the connectors their g 1/4
http://www.magicool....ct_radiator.htm
Hope this helps.
You know, why didn't I think of that, haha.
http://www.magicool.biz/product_280.htm
That helps on the fin count, but not for the option on performance-pcs.com where it asks me what I want to pick for Available Options. I am not using 1/2 or 3/8 OD, which are the only two options to select from.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=27800
