Kempez's Project <<| Black3d |>> **56k**
Soz about the lack of updates. Been busy with review and stuff.
I have some new RAM and a new chipset cooler but I also managed to break a CCFL
Awaiting stock as AC Ryan is the only make I'll have
I'm moving soon so hopefully I'll have some time to get some work done then
Right update. Pics don't do this justice as it looks very nice in real life.
Not fiddled properley with the mobo yet but it installed Windows fine. The temps are a bit high on the CPU but I think I need to adjust the fixings a bit.
Added some drive bay stealthing and still lots more stuff to do like doing the floor in carbon fibre and some more black alu inside but it's looking good so far imo :)
New hole cut in mobo for cabling:
get.php
Dremeled that up as well as some more alu to cover the drive bays
get.php
get.php
There's a couple of scratche that I can polish out (this is my workhorse PC after all), but it's pretty nice shape apart from that :)
Quick UV view:
get.php
get.php
get.php
Current hardware is:
Core2Duo E6600
DFI RD600 motherboard
2 x 1gb Mushkin HP2 6400
MSI 8800GTX 768mb
OCZ Gamextream 850w
Hitachi Deskstar 7K160
2 x Hitachi Deskstar 7K80's (in RAID 0, not installed yet)
Sound Blaster X-Fi fatal1ty edition with breakout
Crystalfontz LCD drive bay screen
Pioneer DVD-RW
Custom Water Cooling:
Swiftech Apogee CPU Block
Laing D5 Pump
Aquacomputers EVO 360 RAD
5 x 120mm SilenX High Performance fans
Ye they're alright, though all 5 makes a helluva racket actually.
The case is really pretty damn smooth - it's annoying me that it looks a bit knackered in the pics
I'd better polish it and take some nice ones :p
They never look as good in picts as in real life.:)
I really love AC fans but got a couple of the Silenx fans, when you take them apart the Silenx are much better made. I use a controller on mine and at 90% the fan is nearly silent.
Looks good kempez! :dribble:
Before anything else, buy some Isopropyl and paper towels, and CLEAN THOSE FINGERPRINTS! :eyes:
