Just built new computer 2 problems left.
milo
Hi all,
So I am in the process of building that computer that a posted on a little while ago. I have run into a few problems.
1)As I installed my OS on SSD in SATA0, and a 1TB WD Hardrive in SATA1, for some reason it wont reconize my harddrive.
2) When I click the restart button it starts to restart but then shutsdown before it can get into windows, then it restarts again but this time it works. Why does it restart twice?
Thanks in advanced milo.
The cables you get and 6gb/3gb, but the hardrive is pluged into a 6gb/s port but i thought that they are backwards compatible
Do I maybe need to plug the hardrive (which is 3gb/s) into only 3gb/s SATA 3 say.
So I managed to get it running, it is now recognised as a simple storage space. Since my SSD is only 60GB how to I make it directly store all my library and future downloads on it rather then my SSD.
Thanks to all, finished the build managed to get everything working. Again thanks very very much for all your help, Milo.
