Is this correct?
nathan
Just installed my new cpu, looking speedfan read outs it says it says 11c (idle).
Can i presume this is accurate?
I'm running on air cooling.
EDIT: under full load (superpi) it goes up to 20c
Can't be? Unless you have a bloody cold room.. I doubt it is at 11oC..:cool:
As MR Rast said give Coretemp ago.
Oh, and check the bios readout.
If it`s running @ 340x6, I`d be inclined to go more with 23 idle.
Still seems low, but it`s not running 400x6. Bios will give u same temp u see on uguru I think.
I no longer trust any temp readout programs as every single one, nearly a year after the E4300s release, gives a drastically different reading
Speedfan + coretemp give same on mine if u plus 15degrees onto speedfan, thats standard with speedfan + coretemp though.
It could well be 23°. The defult fsb for the chip is 333 and the abit boards tack a little extra on so they look better in benchmarks. Ive found uguru to be pretty close to my K102s reading.
and @ 1.16v it could be right*
*as close to right as software gets
