FourLions
How to save every thing on firefox easy even put all your info on another comp
The pics are from my modded theme on windows 7 but layout is the same
PLEASE KEEP THIS FOLDER SAFE IF ANY ONE USES IT DOES HOLD ALL YOUR PERSONAL STUFF
my spellings not that good but i try
STEP 1
Top of your firefox click help , a box opens up choose (Troubleshooting Information)
Then a new TAB opens up , this is the part you nead to use
CLICK on the part next to Profile Folder (Show Folder)
A folder will open up , NOTE THIS IS ALL THE INFO EVERY BIT FROM LONGINS SAVED PASS WORDS,
HISTORY (EVERY THING)
NOTE top of this folder gives up the exact place where this is located rite at the end
the folder on mine is this , Please note yours will be diffrent but allways default at the end
STEP 2
That is the folder that you nead to copy , you can ether (copy and paist) every thing in this folder
to a new folder rename to what ever you want dosent matter just solong has u remember the name
or fined the folder just follow each step along the top of the default folder to fined it all
them steps leads you to it . PLEASE NOTE THE NAME WILL BE DIFFRENT ON YOURS AND ANY NEW FIREFOX THAT
YOU INSTALL BUT ALLWAYS THE SAME PLACE.
STEP 3
Ones you have your folder you can follow the same path on the new Firefox fined the (default folder)
open that default dolder , you can ether highlight delete the new info in the default folder or just
paste over the new info inside the default with the info that you saved from inside the folder that you
named from the old Firefox. YOU WILL GET A POP UP WINDOW ASKING WHAT YOU WANT TO DO IF
YOU DESIDE TO PASTE OVER THE NEW FIREFOX INFO , (JUST REPLACE ALL)
WARNING PLEASE NOTE [DO NOT RENAME THE DEFAULT FOLDER ON THE NEW FIREFOX]
There you have it all done .
FOR THOSE WHO DONT kNOW HOW TO COPY - PASTE
step 1
COPY - GO TO THE TOP OR BOTTOM OF THE CORNNER OF WHAT EVER YOU WANT TO COPY
HOLD YOUR LEFT MOUSE KEY DOWN SLIDE OVER THE PARTS THAT YOU WISH TO COPY SO IT
HIGHLIGHTS IT, U CAN SEE IT
THIS WILL BE THE PART WHAT EVER IS HIGHLIGHTED TO BE COPYED.
NOW OVER THE HIGHLIGHTED PART RIGHT CLICK ON YOUR MOUSE, A BOX OPENS UP YOU CHOOSE
WHAT TASK YOU WANT . SELECT (COPY), ON LEFT CLICK OF YOUR MOUSE.
That is all the highlighted copyed
STEP 2
PASTE - OPEN A NEW EMPTY FOLDER RIGHT CLICK AGAIN A BOX OPENS UP ASKING WHAT YOU WISH TO DO
PIMPLE REALY - PASTE
THATS IT SIMPLE BUT IF YOU GO RONG JUST FOLLOW THIS STEP COPY PASTE THIS INFO TO A NOTE PAD
ON YOUR COMP SAVE IT HAS WHAT EVER U WISH
STEP 1
STEP 2
STEP 3
step 1
STEP 2
