Hello,
so, I'm building my first computer (the first peaces just arrived, waiting on the others), I would like to know your opnions about the way I plan to set the airflow in my pc.
First of all, the config:
Case - HAF-X
CPU - i5 2500k
Cpu Cooler - H100 (standard coolers)
VGA - gtx 570, standard cooler
Memory - 8gb ram, corsair vengeance
Motherboard - p67 sabertooth
I bough an aditional fan for the optional spot, and here is a screenshot of how I think it would be better (I know the best way to do this is tryng all the options and check what works better, but this is just a topic for ideas
, maybe someone already did this!)
what do you guys think?
ps: Im using a 50mm as assistant fan on the sabertooth (recomended by the manufacturer) and a memory fan (not cause I think the memory need anymore cooling, just cause I tough it would help keeping the motherboard cooler
ps2: I plan to overclock the cpu as much as I can, so optimal airflow would help
Case - HAF-X
CPU - i5 2500k
