alienware
Banned
Hi all. Kambo and I agreed to run some benchmarks in another thread so I've spent the afternoon running plenty of benchmarks. Note I have not ran them on a single GPU as most of them (with the settings I have used) fail to make playable frame rates.
First of all this might be of interest (Frame rating)
http://forum.overclock3d.net/showthread.php?t=52258
So let's move on, shall we?
Firstly I want to make a note of scaling percentages.
Nvidia's drivers have an inbuilt tool that reads the GPU usage on SLI and displays it as a single bar. This bar then reaches up and down from the center point and displays the usage as a green bar from the center. The top center bar is GPU1 and the bar from the bottom is GPU2. Note here are the bars being used to 100% over both GPUs (in 3Dmark 11)
And here they are in Dirt : Showdown (around 85% usage)
And here they are in Mafia 2, which tbh scales very poorly (you will see this in the results).
Our Test System.
Today I have used my own rig, pictured here
The specs.
Alienware Area 51 ALX with 1200w PSU
MSI Z77A-G45 motherboard
Intel Xeon E3-1220 (Sandybridge) CPU clocked @ 3.4ghz
12GB Mushkin Radioactive/Blackline
120GB Corsair SSD for boot drive
Numerous 500GB drives to store games
Corsair H60 cooler single fan
Some information
CPU (Note CPUZ doesn't understand it properly so it's all out of whack)
And our GPU set up. SLI 670s running @ 8x PCIE 2.
And our recorded temps after an hour of benchmarking.
The Benchmarks
First up was 3Dmark Vantage,noting this is an old version that will add Physx PPU scores to the CPU score so ignore the CPU score, basically.
3Dmark 11
3DMark (13)
Unigene Valley 1.0 Note -ran on Extreme HD setting
Unigene Heaven 3.0 settings
Unigene Heaven 3.0 result
Unigene Heaven 4.0 settings
Unigene Heaven 4.0 result
The games... Dirt Showdown results. Game ran on max with 8XMSAA
Hitman : Absolution settings NOTE I am running 8XMSAA here
Hitman : Absolution result
Mafia 2 settings
Mafia 2 result
Metro 2033 settings
Metro 2033 result
Streetfighter X Tekken settings
Streetfighter X Tekken result
Tomb Raider results, max possible settings
Sleeping Dogs settings, 8xMSAA Note, FRAPS can not take shots of this with SLI running so I had to take photos.
Sleeping Dogs results
Crysis 3 settings
Crysis 3 chosen level for manual benchmark
Crysis 3 result
Crysis settings & Benchmark result
Batman Arkham City settings
Batman Arkham City results
Just Cause 2 settings 8XMSAA
Just Cause 2 result
Far Cry 3 4XMSAA max settings
Far Cry 3 chosen level. I decided to ride around on a quad bike
Far Cry 3 result
Final thoughts.
So to those out there that say that SLI is a waste of time on one 1080p monitor? well, up until the recent bout of games released (such as Crysis 3, Sleeping Dogs, Hitman, Tomb raider and so on) I would have agreed with you. However, as can clearly be seen some of these titles are barely playable even on SLI. Returning to one card produces unplayable frame counts in most of the new titles, though granted that's mostly when you crank the MSAA.
Please feel free to run these benchmarks yourself for comparison reasons. Any results can help but please be careful to make sure you use identical settings otherwise results will be useless.
Cheers!
Our Test System.
The specs.
Some information
The Benchmarks
3Dmark 11
3DMark (13)
Mafia 2 settings
Mafia 2 result
Metro 2033 settings
Metro 2033 result
Crysis 3 settings
Crysis 3 result
Just Cause 2 result
Far Cry 3 result
Final thoughts.
Cheers!
