Asperatis
So I made a basic gaming system for a friend of mine but I ran into an issue with the gpu.
To begin with these are the specs:
Fractal design core 1300 case
Intel 4460 cpu
ASRock B85M pro4 mobo
8GB Crucial Ballistix 1600 ddr3
Sapphire Radeon R9 380 4GB
Corsair CS550M psu
Noctua NH-U12P se2 cooler
Seagate 1TB hdd
Samsung 850evo 250GB ssd
Everything has been installed but the problem I'm having is that the gpu isn't giving any output (using dvi port). Onboard graphics work fine and both fans on the gpu are spinning as they should be. I also cannot install the gpu drivers that came with it (amd catalyst etc, also tried the newest driver I found on the web, 15.10 beta if I'm correct). When I try to do it, I get an error mid install and it aborts. No unknown devices can be found in device manager either.
Any ideas what the problem could be? Yes the power cables are all plugged in and I'm sure 550W should be plenty for this system.
One other thing I noticed is that the seal on the box was broken and the card showed some minor scratches all over the shroud, giving me a rather clear indication it is a refurb. My friend did not open the box prior to giving me the components, I checked it with him.
Asper.
Intel 4460 cpu
Corsair CS550M psu
Seagate 1TB hdd
Asper.
