Get A Vista Rc1 Key Now!
bazx
Found a way to get Vista RC1 Keys from Windows.......even though the program is closed.
1. Go to this Website and pick a country and click "go".........
http://www.jkg.in/34-how-to-obtain-the-windows-vista-beta-2-key-serial-for-free.htm
2. Input your Hotmail email and password and sign in....
(create a new one if need be........you wont get anything if you have used the same email before)
3. Microsoft will sometimes show you the key in the browser but most of the time they send it to your hotmail.
They will always send it even if they show you the key...........
Works like a charm
just got this from a mod (Scaramonga)@ at tnt
Is there any point in installing Vista at this point?
I was sent a key, but thought it would be more aggro than it's worth..
regards
Raja
regards
Raja
many things in life are aggro the question is do you want to try vista or not?
regards
Raja
I installed it just to test but ive now im using it as my main OS.
Same hear, but still a lot of bugs and drivers to be sorted out to get it right, so i don't think it will show an appearance in November, also it is still very hungry on the system compared to XP.
