So today the last piece of the jigsaw arrived. Must say looking at it in person i dont see where they get off charging £25 for this rather small piece of metal lol.
I guess at least part of the issue is if you use the 9x120mm fan mount you have a better chance of buying £100 worth of phobyia fans as opposed to £40 worth with the 180s lol.
So I fitted the fans to the rad, yes, they are held in place by cable ties, i didn't trust the screws that came with the rad not to put some nice holes in it
Ok so time for some testing results
What I did was run prime 95 and furmark at the same time, leave the system for 30 minutes then take a screenshot of HW monitor
First up, with all the fans turned up to full
Pretty impressive temps IMO, with an ambient temp of 23C that gives us delta temps of 48 on the hottest CPU core and 23(!) on the GPU
Next up i put all the fans on the lowest they would go, to do this i turned them off and then ramped up the percentage in speedfan until the fans started spinning again. So its the minimum power needed to start the fans not keep them spinning.
Again not bad, with an ambient temp of 22 we get a delta of 53 on the hottest CPU core and 26 on the GPU.
Next i ran the rad totally passively, all fans turned off
With an ambient temp of 23 this gives us delta temps of 71 on the hottest CPU core and 47 on the GPU.
Running passively this was probably a bit hotter than I would have liked, but really no application is ever going to be this stressful on the system.
One thing that might be worth noting is that i had to do 2 passive tests on the first time after 20 minutes or so i had a random shutdown, not sure if it was related to heat or not though.
All in all i'm very very impressed
