Fractal Design Kelvin S36 pump
Dawelio
Active member
Hey guys,
So after talking Tom, he said that the S36 kits I had were loud, due to I needed to turn the pump down... now I have no idea how to turn the speed of the pump down.
Do you do it in the BIOS or where? :huh:
Thanks,
Chrazey
Pretty sure they don't have any software like Corsair Link so it's just the old school way of using a resistor cable, like 7v cable. Unless they released their own software but I haven't heard anything about that. Though tbh I wouldn't want to run the pump any lower than max speed.. 9v cables would be the absolute minimum I would go. That's just my opinion though.
This one is fine to hook up to the motherboard -
run tests at 100% for temps
turn down to 90% - run temps
keep going till youre happy and its not effecting your temps much.
