FML Thread
Where does this thread belong?
  • Humour
    Votes: 2 20.0%
  • Serious discussion
    Votes: 5 50.0%
  • General off-topic
    Votes: 3 30.0%
  • Total voters
    10
  • Poll closed .
Finally found a girl that actually likes me, but with two jobs, a ton of debt (for a student anyway) and zero to very little time on my hands having two simultaneous jobs, studying for exams and school at the same time. I'm not sure I can get into a relationship right now, well, sheit :/
tired & angry = BROKEN MONITOR when fucking .net framework wants to dick about for nineteenth millon time.. in the market for a new monitor now ffs... oops
done that 3 times before (once on laptop)
also went through 2 mouses because of that :p
When i was ~9-13 i used to get really pissed off at call of duty mw2 multiplayer
When i was ~9-13 i used to get really pissed off at cod mw2 multiplayer
just doing my head in, how hard can it be for fecking windows 8.1 to actually do as its fecking told?!!!!!!!!!!! half tempted to drop kick rogy & get an xbox one at this rate!
i have broken so much it untrue XD monitors whole pcs xboxs ECT XD
I know windows 8.1 is annoying
i installed it 3 times yesturday, each time with diffrent problem.
What really pissed me off was that during the installation i entered the wrong account, and i could not delete it at all, even after creating other admin account. Finally i managed to delete it manually and use the other admin account, But, every time I ran something as administrator, it would tell me to log in to a admin account, but it didn't exist apparently! i could not log to grant admin privileges because apparently there was no admin :eek:
im on my 10 install & just about ready to cry, its utter balls, i am making a thread shortly tempted to go back to windows 7 as this is a joke now!
My logitech driving force GT that i've had for 4 years is starting to fall apart. The sroud of the cables is coming off, power brick is broken so i have use a laptop one, and now one of the 2 bolts that hold the steering wheel that hold it in place has broken off, shifter does not work (lucky the paddles at the back of the steering wheel do)
costed me £110 i think, but the way i used it i think it lasted pretty long
That luck is worse than Bad Luck Brian... ok maybe not that far but pretty bad.
I get horrible artifacting when playing Battlefield 3 :(. I think my accursed 280x really is on its way out.
Bake! Bake! Bake!
Bake in the oven.
TBH, you could try using your hair dryer lol but thats going to be temporary or wont work at all. Take off the plastics or youre gonna melt them!!!! if you are going to try this with hairdryer with max temp setting, make sure you blow on the memory chips
Bake! Bake! Bake!
Bake in the oven.
a proper heat gun would be better, a hair dryer wouldn't get hot enough to melt the solder which is the whole point.
Worked on consoles so it should work on pc gpu, but it was a very temporary solution and reflowing the system board in the oven was a much better solution
I think its blown a capacitor. I'll post photos in a bit.
I think you mean a blown mofset...
If anything blows in vrm's its almost always a mofset
Depending on how many power phases your gpu has, it should still work with missing power phase
Bake! Bake! Bake!
Bake in the oven.
It's a 280x you lunatics, chances are he still has RMA rights.
I should do although as with the other fault with this f**king card its hard to get it to produce the issue although I'll hopefully get some footage of it later.
