I am not a hundred percent on the choice of hardware in my soon to be new rig. I think i have it narrowed down to the following.
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($374.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper T4 70.0 CFM Rifle Bearing CPU Cooler ($14.99 @ Newegg)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard ($238.99 @ SuperBiiz)
Memory: G.Skill Ripjaws Series 16GB (4 x 4GB) DDR4-3000 Memory ($104.88 @ OutletPC)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive ($159.75 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card (2-Way SLI) ($643.99 @ NCIX US)
Case: Corsair 780T ATX Full Tower Case ($169.99 @ Newegg)
Power Supply: EVGA 1000W 80+ Gold Certified Fully-Modular ATX Power Supply ($125.98 @ Newegg)
Operating System: Microsoft Windows 10 Home Full - USB (32/64-bit) ($105.99 @ SuperBiiz)
Case Fan: Cooler Master Blade Master 76.8 CFM 120mm Fan ($6.78 @ OutletPC)
Fan Controller: Gelid Solutions SpeedTouch6 Fan Controller ($43.98 @ Newegg)
Monitor: Acer B286HK ymjdpprz 60Hz 28.0" Monitor ($380.29 @ Micro Center)
Other: XSPC RayStorm D5 Photon RX360 V3 WaterCooling Kit ($294.00)
Total: $3372.13
Honestly would like some advice like when I get around to it will the d5 be able to handle the 2 GPUs and another radiator in addition to the CPU and current rad. I think for price the monitor is good choice but is 2ms response to much for usage. Finally I understand that the 5820k might be a little overkill for gaming but I will be doing some amount of rendering and 3d modeling.
Guess I'll answer the questions while I’m at it.
I live in the USA. My current budget is 3400 dollars. I will be needing a monitor with this build. The build should include an OS I prefer home to pro as I don't need the single file data encryption that pro offers. Though due to a problem I had with a motherboard in the past I will not buy an OEM copy as I had to buy the bloody thing twice. The rig will be mostly used for gaming with some minor 3d modeling and render on the side. I honestly want to move to 4k gaming. The system will be overclocked maybe not the ram but only due to the fact that I have had bad luck manually tuning it.
Total: $3372.13
