Firestrike Ultra 4K Benchmark arrives monday
Kaapstad
Active member
https://twitter.com/Futuremark
This should have a few GPUs sweating.:cool:
How does your set up run on 2k atm? what are you expecting?
I have been using 4K for a while now and it runs fine.
As to Firestrike Ultra it will be interesting to see what Futuremark use for settings as this will effect the workload as much as the 4K resolution.
I have run Firestrike Extreme @4K before and that puts a lot of strain on the PSU. The GPUs don't suffer from a CPU bottleneck so they spend most of the time @100% load and use a lot of watts.
I'll be giving it a go if I can get it to work with DSR, i'm not expecting much of a score though :p
I can already picture the last part of the bench where the fire and ice dudes are battling it out running at about 2-3fps :\
We must get Tom to ask for another of those 290x2 DEVILs by powercolor and make that review already :D
That benchmark will be just right for the cards
and i just ordered a new 1080p monitor too lol (the downstairs one got broken some how, exactly the same day i decided id go dual monitor up here again and to use a 19" spare on the downstairs rig
so i dont think i will be able to do the 4k test. i have a sneeky suspicion if i try it will tell me my monitor cant do it.
and if it didnt i think my 7870 would explode from the work load lol..
whilst we are here.
is there any form of promotion or disscount on any of the 3d mark banches "im aprticularly interested in 3dmrk 11 or the newest 3d mark, vantage not so much as i dont mind using the demo of that"
i know i can "aquire" them online for free but i like 3dmark so id like to buy the app(s) but i would like a discount too lol.
This is the Firestrike Extreme bench raised to 4K in the custom settings on some 290Xs.
AMD Radeon R9 290X(4x) @1000/1250
Intel Core i7-4930K @4.0
Graphics Test 1 55.53 fps
Graphics Test 2 36.18 fps
Physics Test 48.17 fps
Combined Test 17.59 fps
Graphics Score 10078
Physics Score 15175
Combined Score 3782
http://www.3dmark.com/3dm/4328443
Physics Score 15175
Combined Score 3782
I might just be able to make it through with my 970 overclocked to 1588
If I divide your FPS by 4 it gives me an estimate as to what I will get with one card
Test 1 ~13 fps
Test 2 ~9 fps
Physics Test - not sure seen as it is CPU bound
Combined Test ~4 fps
It will be worth it to see how little of a score I get :p
Test 1 ~13 fps
Test 2 ~9 fps
You should do a bit better than you think.
Physics Test is the same whatever resolution you use you score the same.
Combined Test does scale with resolution but a big part of it is CPU grunt so extra cards only help a small amount.
I will be running a thread for it the same as the other ones I do.
Just ran it on mine using the Fire Strike Extreme Profile but set to 3840x2160 and here are the results, with Shadowplay turned off and a +150 Core +300 Vram overclock.
http://www.3dmark.com/fs/2955392
Graphics Score: 5203
Physics Score: 14241
Combined Score: 2484
Graphics Test 1: 31.27 fps
Graphics Test 2: 17.72 fps
Physics Test: 45.21 fps
Combined Test: 11.55 fps
Need to run it again when it's properly released and see what is causing the "Time Measurement" to no be available.
Also need to sort my cpu cooling out as the H100i isn't cooling my 3930K @ 4.0ghz that well, even with 4 AP15's on it.
It is out! 3D Mark will update when you open it.
My first run
2500K @ 4.2
970 @ 1504/1900
344.16 drivers
3DMark Score - 2850
Graphics Score - 2845
Physics Score - 7306
Combined Score - 1501
Graphics Test 1 - 15.94 fps
Graphics Test 2 - 10.11 fps
Physics Test - 23.2 fps
Combined Test - 6.98 fps
http://www.3dmark.com/3dm/4350653?
This is with R9 295X2/290X for a Tri-Fire config.Samsung 4k monitor.
4790K 4.8ghz/Catalyst 14.9.1 beta
3DMark Score6913
Graphics Score7390
Physics Score13456
Combined Score3125
Graphics Test 140.45 fps
Graphics Test 226.65 fps
Physics Test42.72 fps
Combined Test14.54 fps
http://www.3dmark.com/fs/2964802
Just did a run on mine, managed to get it to bench at +195 Core +300 Vram, on both cards with cpu at 4.0Ghz.
3DMark Score: 5156
Graphics Score: 5221
Physics Score:14090
Combined Score: 2522
Graphics Test 1: 32.23 fps
Graphics Test 2: 17.52 fps
Physics Test: 44.73 fps
Combined Test: 11.73 fps
http://www.3dmark.com/fs/2966093
Put's me at 28th on the Hall Of Fame.
Can't OC as airflow is poor for my GPU and I've not gotten too far with my cpu without temperature issues. i7 4770k@ 4ghz, card at stock
3DMark Score2467
Graphics Score2407
Physics Score11308
Combined Score1243
Graphics Test 114.41 fps
Graphics Test 28.22 fps
Physics Test35.9 fps
Combined Test5.78 fps
http://www.3dmark.com/3dm/4353201?
Here's a run on my X99 system. drivers:344.11
5960X@stock with 2 Evga 780 ti Kingpins@factory oc
3DMark Score5461
Graphics Score5554
Physics Score16756
Combined Score2556
Graphics Test 134.36 fps
Graphics Test 218.62 fps
Physics Test53.2 fps
Combined Test11.89 fps
http://www.3dmark.com/3dm/4353559?
Does this only add proper 4k support?
Yes, but if you don't have a 4K screen it downsamples. (renders in 4K and then resizes the image to your res) You still get the same performance hit as if you were running 4K native though.
I am having my first break since this bench launched. It seems to be very popular with lots of people posing scores.
I've been trying for the last hour to break 3000 :D
Sooo close.. Trying to find the balance between core clock and memory. Also performance is dropping off at 1564Mhz, I can go slightly higher but the score drops :(
970@1558/2000
2500K@4.7Ghz
344.16 Drivers
3DMark Score - 2987
Graphics Score - 2963
Physics Score - 8067
Combined Score - 1588
Graphics Test 1 - 16.45 fps
Graphics Test 2 - 10.59 fps
Physics Test - 25.61 fps
Combined Test - 7.39 fps
http://www.3dmark.com/3dm/4355225?
