Finally started my new build
Now it's nothing to really worry about as the fair temp is 100 I believe but I have heard of people not hitting 60 on load and that makes me want to slay even more than the noise haha. Bottom line you are king to have a very nice system in your possession
For the plate the SSD's mounted to - I would go white - think it would highlight the red of the SSD drives more. Any thought to some white LED back there?
i agree the white would deffo highlight the red of the ssd´s.
i thought about led havent bought any yet. i want to finish the case first and then do the icing on the cake
thats alright then :) and cheers mate
loving the case and setup, cant wait to see the final! I sort have the same specs just waiting for them to turn up!
cheers buddy... i have waited two weeks for my stuff to arrive... and still waiting for a couple of bits and pieces
little update
another little update
this morning i´ve painted the plates for the handle.
this is how they look like now
the handle riveted in place
i think it looks just like the old one
with the fans installed
now the result
and again
and from above
now the plates are black you cant really see them from above which is just what i wanted. :)
this morning i have also done the primer coat on the ssd mounting plate
will have to go and buy some white paint tomorrow so i can finish it.
tell me what you think :)
and another update :)
this morning i got the white paint and painted the ssd mounting plate
this is how it looks like now
with the ssd´s installed
the mounting plate rivited into the case
mounting plate rivited into the case with ssd´s installed
a look from the other side
and the final result
i also thought about what tom said about the four fan idea... and he is right, it looked a bit weird + plus the bad airflow, so i thought about something else...
i made two little plates to fit a third fan in the front of the case they will be attached to the upper harddrive cage
one of the plates
and from the back
the front with three fans installed
as i said before these fans will be replaced by some lovely corsair af120´s.
more updates to come...
tell me what you think and thanks for watching :)
its time for a update
more hardware arrived today
my lovely new af 120´s
love the look of those fans
the af 140 also arrived today
the af140
i´ve put the white rings on the fans
the h100i was also part of the delivery
the opened box
the beautiful h100i :)
with the fans fitted
the front of the case with the new fans fitted
the front with the cover back on
the af140 and h100i fitted
push/pull
the fan cables... three coming from the front, five from the top and one from the back... need a extention cable for the one from the back :)
now i´m just waiting for the ax760i and the led strips and than i can start putting it together... cant wait :)
Looks really good, but I don't like the look of that 4 fan thing, I can't quite make out what it is for...?
Theres a few other things that don't make alot of sense but I'm not goona complain. Its your build
