Favourite way to flush a new radiator?
Snortan
I'm waiting for my WC parts to arrive this week and the only part I'm not completely clear on is the proper way to clean the radiator (NexXxoS UT60 480mm) so I just wanted to hear what you guys prefer doing.
Fill, shake, empty repeat. That's how I do it mate. I no some people connect it up to a tap, and flush it for a while, others add a small amount of vinegar to the water. I no Mayhems have just released a Blitz cleaning kit that is meant to be really good.
I just boiled a pot of distilled water, let it cool down for a bit, and fill / shake / empty / repeat. But be sure to wear oven mitts if you go that route.
I tend to put warm clear vinegar in mine, give it a good shake, let it settle a bit and shake some more. You wouldn't believe the crap that comes out of some rads.
That twice, then dionized water flush twice until no more particles/colour change in the water then seal them up ready to go
Do One nede to flush the res and blocks as well?
I've never flushed a block or res. The reason for flushing rads is to get rid of flux/solder left over when the rad was assembled. Blocks and reservoirs obviously aren't made the same way a rad is, so there usually isn't any crap in them.
Thank you.
