Dawelio
Active member
Hey guys,
So I have been doing some research and wanted to ask you guys, what you may think of these?:
https://www.newegg.com/Product/Prod...cm_re=dust_filters-_-9SIA53V1KU2957-_-Product
https://www.overclockers.co.uk/dustend-g3-dust-filter-extra-fine-and-adhesive-950mm-cm-000-du.html
I have recently gotten the Cougar QBX ITX case and unfortunately the side panels have rather huge mesh on them, but no dust filters.
As you can see:
So I was thinking of maybe getting something like the filters above and stick them over the mesh part, to try and get some dust filtering inside of the case atleast. Rather than having it non-filtered.
If anyone else may have any other tips, recommendation or so for dust filters/filtering, please do share.
Thanks everyone,
Chrazey
As you can see:
Thanks everyone,
Chrazey
