Dual DVI graphics card for dual display setup?
3lusive
Hi guys,
I currently have 2 identical (1920x1080) monitors that I want to connect to my pc for a dual screen setup. Im currently using the integrated graphics that come with the i5 2500k (Intel HD 3000), which supports two monitor setups but only DVI + VGA and not DVI + HDMI - you cant have two digital connections basically. This means that when I connect with DVI + VGA, the VGA monitor looks less vibrant, and it seems like the whole system becomes less stable when I connect the two monitors (I assume because of Intel's crappy drivers). It does work ok but ideally I would like them both connected via DVI (for two digital connections).
I dont game on this pc, but I would like a graphics card that will be stable, run quietly, and be compatible with my Corsair 430W psu, and of course will run two monitors without any problems.
My motherboard is a P8H67-M PRO with 1 PCI-E x16, 1 PCI-E x4, and 2 PCI slots.
I have a budget of about £100
Thanks
GTX 550, if your gonna use CUDA, or a passive 6670(sapphire just relesed the ultimate version) if you want silence.
