VonBlade
Hi.
I had got XP installed on its own on C. Has been for a while.
To install 7 I shrunk the partition, made a new drive, clean installed 7 to that.
Got the dual boot menu fine. 7 loads fine.
Finished fiddling with that, went to load XP. Loads but never loads explorer. So I can see my wallpaper, but nothing else does anything.
7 seems to have made itself C, and XP G (other data harddrives already assigned).
I believe this might be why XP isn't loading, but from 7 I can't change itself from C. And I certainly can't change XP to C because 7 is there already.
Help
(Yes I appreciate it's my own fault for trying to dual-boot for the first time ever. Yes I know that Linux probably hasn't got this problem
Any help appreciated. To be honest I'd be happy just to get back to XP without a reformat.
VB
Help
VB
