cybermaniac
hey guyz
this is just in case ne1 else has this problem:
lemme just outline the problem, then the solution.
motherboard: DFI LanParty NF4 SLI-DR EXPERT
problem: when you try and switch computer on via power button (normal, not the onboard EZswitch), the computer refuses to switch on, only when u switch it off manually (via power switch on back on PSU/pulling power plug out, waiting 5 secs for power to dissipate across the mobo then switching it back on (via switch on back/plugging it back in)) does the computer actually switch on via power switch in front.
solution: in the BIOS under integrated peripherals (i think, not sure on that...basically where it says switch on via USB, via mouse, via keyboard etc), there is an option there saying: "switch on by button".
i cudnt believe my eyes when i saw it....
but neways......u might wanna sticky this/rewrite this just in case ne1 has the same problem and decides its a problem with the mobo and RMA's the poor thing.
