define S side panel not closing fully
katiekitsune
the fan side side panel of my wont close fully, the bottom of it slides up fully but the top wont reach the thumb screw hole. is there any way to fix this or should i just live with it?
Hi have you got a 140mm fan on the rear of the case because i found that when i changed my fan the side panel was hitting the the mounting screw for the fan and would not close properly
