Mick.T.Phallus
My xspc d5 pump making all the right noises but no water is moving, when I first turned it on the water went down then I got a leak turned it off fixed the leak. Now i can hear the pump and water sounds like it's swirling inside the res but nothing is going down the tubes!
Is it clucked?
Sussed it when I fixed the leak I tipped the radiator to one side to get rid of the water and it created a big air bubble once i'd tipped the water back over the pump started pumping!
Is it clucked?
