Hey, In the process of overclocking at the moment and have hit the 4GHz mark
but it seems if I now go over it everything will freeze once the max temp Prime gets under way, here are my settings at the moment (I am running a water-cooled loop, A Thermalchill TA 360 with EK supreme HF CPU Block):
Speedstep, c1e and intel turbo are disabled
LLC = enabled (I have seen people mention 50% and 100%, how would that be done? or is it something different just with a similar name?)
ratio = 20
bclk = 200
pcie = 100
dram = 1603
uclk = 3208
Dram timings = 6-8-6-24
core speed = 4000
CPU voltage = 1.30
CPU pll = 1.80
QPI/Dram Core Voltage = 1.325
I think all other settings are just on auto.
The temperatures have not gone over 65 degrees yet. I just tried changing the multi to 21 but that resulted in a freeze. So has anyone got any advice on what I need to change etc ? Also a big question that I've been wondering is once you get to 200 BCLK do you then just change the multi ? because I've seen tom say like now aim for 200 x 23 and on his youtube page it says his on 200 x 23. So I am rather confused because I thought from things I've read etc that you just leave the multi at 20 and change the BCLK or is that just until the 4GHz mark?
All advice welcome as always and I would be exceptionally happy with an answer to that question above, Thanks very much
Oh and Tom if you do read this, I am aware you are tired of answering 1366 overclocking questions so don't feel obliged to answer this one as well
ratio = 20
bclk = 200
pcie = 100
dram = 1603
uclk = 3208
core speed = 4000
CPU voltage = 1.30
CPU pll = 1.80
