riesza
Hey guys.
I upgraded my PC very recently and this doesn't look like it's healthy for the CPU.
The first picture is it running at stock, the second with the BIOS X.M.P. mode, I don't even want to try to OC it manually if it's getting that hot already. This is running a Blend test with Prime95 for just a few minutes, CPU at 100%. But even then, it can't be normal for it to reach 75°C+ with default stock settings, can it?
I have a Thermaltake Armor Jr. and I'm running a i5-2500K, MSI GTX 560 Ti slightly OC'd, 4GB Kingston 1600 Mhz RAM, P67 Sabertooth and a Corsair TX650W.
I have a stock cooler on the CPU and a 120x120 fan on my frontside, primarily cooling the HDD. Do I just simply need more fans plus a proper heatsink/fan on the CPU or is the problem a different one?
Thanks for reading, I hope you can help me.
Not sure if it actually uploaded the image so here it is again:
