Grey_beard
I found the reason for all those temps. It was the CPU itself. Swapped to other one and everything is OK now.
4.7 GHz with 1.36V idles at ~40*C, ~90*C under prime and ~70*C while gaming.
Fans are set from ~550(lowest possible) to 1800 RPM max. Ambient 21*C.
Thank you for the support.
No problem at all. I'm just glad that you've got it all sorted out
