Hi everybody
I’ve been playing with a new fan design concept that is essentially a hybrid of a centrifugal fan and an axial fan.
It’s my understanding that a regular axial fan will blow threw and sideways. To me this means that the sideways motion of the air is wasted efficiency.
Axial fan:
The centrifugal fan is a much more efficient design but usually blows inn a sideways motion inside a casing of some sort like a GPU fan or a car turbo. This means it can’t be used as a traditional computer case/rad fan.
Centrifugal fan:
My idea is that the centrifugal part of the fan will have the blades reversed so it can suck air inn and towards the center of the fan. Then the axial fan blades will propel the air threw.
My concept design:
I believe that if the air is forced to the center the fan, then the axial blades will be able to impart more force on the air as the air pushed outwards is counteracted and surpassed by the inwards force of the centrifugal part off the fan. This effect will hopefully create more static pressure and a straighter airflow through the fan.
The images are only supposed to represent a rough visualization of the concept so size, shape and angle of the blades are somewhat irrelevant because it’s the idea I want to discuss.
What do you guys and girls think of this idea?
Axial fan:
Centrifugal fan:
My concept design:
