Coms settings needed for Asus A8N32
sacha35
Hi all has anyone got the coms settings for the ASUS A8N32 motherboard, some things in there I just don’t no, also is there anyway to raise the volts on this mobo with some kind of volt mod as it seams that all the X2 chips are locked down to 1.4v and even with the 200mv enabled this still only gives 1.6v there about as it seams to under volt a bit, I no there was a volt mod for the A8N going around but did not look into this, would be nice if the overvolt on this was 300mv instead of just 200mv, or am I going about this the wrong way, is there some way of unlocking the CPU to allow higher volts?
