cl_interp_ratio explanation
equk
Since the newest patch valve seem to have removed cl_interp (well it's there but inactive). Not sure why they've opted for this new thing other than being able to set a max+min ratio. Altho it's no good without enforcing a minimum updrate.
You can work out the interp from a simple calculation ($cl_interp_ratio ÷ $cl_updrate = *interp*)
For the OC3D server at current - rates are enforced to 66 minimum
*cl_interp_ratio is 1 by default
*sv_client_min_interp_ratio is 1 by default
*sv_client_max_interp_ratio is 2 by default
So the min and max interp on the 66 enforced server would be 0.015 and 0.03. (u can go to 100tic on some OC3D so min - 0.01)
It's still quite a range tho.
It still doesn't lock down the interp command tho (unless you change the sv_ vars) and is a bit confusing.
The main thing to remember is if you (or a server) change(s) your updrate your interp is also going to change.
just found some data that makes more sense :)
cl_interp_ratio simply causes the interpolation delay to be calculated off the clients cl_updaterate (The amount of updates the clients receive per second. This will not exceed the servers sv_maxupdaterate or servers tickrate, which ever is the smaller)
The outcome for this is as follows:
cl_interp_ratio 1.0 cl_updaterate 30 interpolation = 0.033
cl_interp_ratio 1.0 cl_updaterate 35 interpolation = 0.029
cl_interp_ratio 1.0 cl_updaterate 40 interpolation = 0.025
cl_interp_ratio 1.0 cl_updaterate 50 interpolation = 0.020
cl_interp_ratio 1.0 cl_updaterate 60 interpolation = 0.017
cl_interp_ratio 1.0 cl_updaterate 66 interpolation = 0.015
cl_interp_ratio 1.0 cl_updaterate 75 interpolation = 0.013
cl_interp_ratio 1.0 cl_updaterate 80 interpolation = 0.013
cl_interp_ratio 1.0 cl_updaterate 100 interpolation = 0.010
cl_interp_ratio 1.5 cl_updaterate 30 interpolation = 0.050
cl_interp_ratio 1.5 cl_updaterate 35 interpolation = 0.043
cl_interp_ratio 1.5 cl_updaterate 40 interpolation = 0.038
cl_interp_ratio 1.5 cl_updaterate 50 interpolation = 0.030
cl_interp_ratio 1.5 cl_updaterate 60 interpolation = 0.025
cl_interp_ratio 1.5 cl_updaterate 66 interpolation = 0.023
cl_interp_ratio 1.5 cl_updaterate 75 interpolation = 0.020
cl_interp_ratio 1.5 cl_updaterate 80 interpolation = 0.019
cl_interp_ratio 1.5 cl_updaterate 100 interpolation = 0.015
cl_interp_ratio 2.0 cl_updaterate 30 interpolation = 0.067
cl_interp_ratio 2.0 cl_updaterate 35 interpolation = 0.057
cl_interp_ratio 2.0 cl_updaterate 40 interpolation = 0.050
cl_interp_ratio 2.0 cl_updaterate 50 interpolation = 0.040
cl_interp_ratio 2.0 cl_updaterate 60 interpolation = 0.033
cl_interp_ratio 2.0 cl_updaterate 66 interpolation = 0.030
cl_interp_ratio 2.0 cl_updaterate 75 interpolation = 0.027
cl_interp_ratio 2.0 cl_updaterate 80 interpolation = 0.025
cl_interp_ratio 2.0 cl_updaterate 100 interpolation = 0.020
Clients can have higher cl_interp_ratio values to accomodate for packetloss & choke.
There are 2 server side variables that limit how large a clients cl_interp_ratio can be, these are:
"sv_client_min_interp_ratio" = "1" replicated - This can be used to limit the value of cl_interp_ratio for connected clients (only while they are connected). -1 = let clients set cl_interp_ratio to anything any other value = set minimum value for cl_interp_ratio
"sv_client_max_interp_ratio" = "2" replicated - This can be used to limit the value of cl_interp_ratio for connected clients (only while they are connected). If sv_client_min_interp_ratio is -1, then this cvar has no effect.
The bottom line is this: interp is calculated off your updaterate. Change your updaterate and your interp will change, it is as simple as that!
