Gurt11
I've got kind of a big update here...
Leds for cpu block
AF120 in the back
Glueing plexi time!
Meanwhile I did the graphics card, which was a true pita. Never again.
Cleaning went ok, but then... Getting the block on took me a long time. Then the screws at the back turned out to be sticking out to far to put a backplate on. I really wanted a backplate, so I really needed a solution. I took it apart again and re-mounted it with the little things from the inside now at the back and the big ones on the inside, plus I used shorter screws without the metal spacer.
The result was that it barely fits, as you can see.
EK told me their backplate for the gtx670 directcuII would fit on the 660Ti directcuII, no problem.
It doesn't. Problem. Nothing keeps the black screws (there's another one on the other side) in. So I'll have to go find little thingies to bolt on on this side.
Meanwhile in the realms of glue
BOOM.
Still a mess at the back
Getting quite close huh
To do:
- 24 hour leak-testing.
- connecting everything + cable management.
- do something with the drive bay?
Only thing is, I've got to go to Rome (Italy) for a couple of weeks. So finishing it will be for after that. Cheers!
Leds for cpu block
AF120 in the back
Glueing plexi time!
BOOM.
To do:
