Case fans
Jamsand
Hey guys, I just bought a coolermaster 690 II advanced and was looking to install some fans in it. Thing is budget already got kind of blown(know how it is you start with I'll just spend this then it seems you can step up for another £10 each time and before you know it you've added £60 onto your budget lol) so I'm looking for some decent case fans now probably about 5-7 fans for £50ish(I know I'm being pretty vague sorry lol)need 1 80mm and the rest are 120mm. suggestions?(try and go for quiet fans like most bit of a noise freak lol)
From memory the cm690 ii adv. comes with 3 fans inc. (120mm rear exhaust, 140mm top, 140mm front led) these fan's perform good and are relatively quiet 19db.
You don't need that many fans mainly:
* front intake
* bottom intake
* top exhaust
* rear exhaust
* side intake
Coolermaster have x4 120mm bulkpack and Nexus have their real silent x4 120mm bulkpack as well just a suggestion.
Thanks tis a good suggestion not expecting to need too many fans as I'm not expecting to heat anything up too much. What would you suggest between the nexus and coolermaster.
I made a mistake the nexus real silent bulk pack includes 5 fans not 4. The coolermasters spin @ 1200rpm (19db) pushing 44.73CFM the nexus' spin @ 1000rpm (18db) pushing 36.87 CFM.
