can't find my HDD :(
ok so i broke my windows 7 install (well Folding broke it)
i put my set up disk in and it cant find my SSD or HDD
i know it is not them at fault as a windows XP disk finds them
so far i have tried
reset BIOS
disabling other SATA controllers
changing the controller the drives are plugged into
changing the mode of the controllers my drives are plugged into
preloading drivers
checking connectivity
1 drive at a time
what else is there to do?
This happened to someone I know, don't know if they ever sorted it out though because I haven't seen them for ages. Anyway a couple of suggestions.
1.Try booting with a Linux live CD Ubuntu/Mint should do. Once you are on the Linux desktop try running the Windows 7 DVD and running the setup.
2.Install XP on a 4gb partition if you have a copy of XP and try the same as I said with Linux and then once you have installed 7 format the XP partition.
How did folding break it? what has it done as all seems fine with my setup - no SSD in mine though, is that what is causing it?
my OC wasnt folding stable so i crashed my windows one to many times and it couldnt recover
just finished fixing it
took a while to get XP to install on my HDD just kept creating partions
and saying i have 800GB of free space on my 500GB hard drive :/
Just been looking on MS support, it seems that if you click on the reinstall win 7 link it takes you to another link that says exactly the same but offers no advice
they then have the cheek to ask if it was helpful ha ha ha NOT!!!
