mihapiha
Member
it really depends what you want. Servers are really good for Folding@Home. CPU WU get bonus points (if you use a passkey). The quicker the WU finishes the more bonus points you get. So it depends on the system. Mine is high-end, even in the server-sector. I get over 400.000 points per day on average but I have also 700W power consumption. In the PPD/Watt ratio I'm doing quite well though.
For folding purposes with your budget I'd skip the CPU-based solutions. These make sense as soon as you get a Intel Core i7-3930k @ 4.2 GHz or faster. The reason for this are primarily the WUs. You see with 16 threads or more, you can get BIG WUs. WUs of over 20.000 base points. These have to be finished in 3 days in order to even get bonus points. A 3930k @ 4.2 GHz stays (just barely) within the tight 3-day deadline. One of those WUs results in 200.000+ points. Unless you can get those WUs and fold them in time, CPU based folding is just not as interesting. These BIG WUs practically double the PPD on average.
With your tight budget, I'd honestly prefer GPU based folding. You only need one threat/core per GPU and it would beat a CPU based system in terms of performance easily in that budget range.
Maybe you can get an old used system and just put a newer nVidia graphic card in there. AMD unfortunately doesn't run as well. If you're look carefully for the right hardware you may even end up in the 200W power-consumption range.
