Can anybody answer this Truthfully?
name='digital.jesus' said:
Why is the Q6600 2.4ghz not the world record holder at speed if it is 9.6ghz like i got in answer to post?
here is a link for the world records of overclocked systems http://www.xtremesystems.org/forums/show... and according to all the answers i got on a post the Q6600 2.4ghz is really a 9.6ghz cpu,another thing why dosent intel advertise it as 9.6ghz,the reason i ask this question is people on ebay sell systems with the q6600 and say it is a 9.6ghz .
(saves y'all jumping to Yahoo)
I always wondered the same. It's definately false advertising for ebay sellers to say 9.6Ghz..
The guys there have said it pretty much.
9.6Ghz most likely is each cores speed added together. So divide 9.6 by 4 and you get 2.4Ghz.
It will only ever run 9.6Ghz if a program you are using uses each core. Which so far we have yet to have a program that uses dual core properly.
The people on eBay think they can scam someone into buying a 9.6ghz CPU when really it is 4 cores which run at 2.4ghz each. ;)
But once some clever programer creates a program that can use all cores for one thing then you will have 9.6Ghz cpu.
The Q6600 cpu has supplied to it via the mobo a clock speed of 2.4ghz.
Effectively the 2.4ghz is the rate each core of the processor runs at.
4 x 2.4ghz = 9.6ghz.
IF it was a situation where each of the cores contributes to the work of the cpu as a whole, i.e. u run SuperPI and all the cores worked on it, the efficiency vS a standard single core cpu would be equiv to it operating at 9.6ghz.
Either way you look at it, the mobo only supplied the cpu with 2.4ghz (unless overclocked of course) so the rating of the processor is 2.4ghz. It`s the clock speed of the cpu.
The clock speed of the processor is a factor of the mobo`s fsb. This fsb is constantly ticking over, as this effective rail ticks over, the cpu uses it to nudge forward instructions for execution. Even if the processor had 8 cores and 2.4ghz was the clock speed, it may effectively be possible to execute commands, or do a job, at 8x2.4ghz (relative to a single core cpu of the same build), but inherently the clock is always 2.4ghz.
Software just isn`t up to the standard where u can say "9.6ghz" and even if u did, it would be missleading because the clock IS still 2.4ghz, across 4 cores. (there are rare programs that use the cores well, but even so).
Confuzed ?
Thanks for all the useful info guys,kinda sums it up for me now,i had a q6600 for sale on ebay and advertised it as 2.4ghz,seeing the vast majority selling there systems as 9.6ghz,even some saying 13.6ghz,i just didnt belive this to be true and didnt follow there way of advertising.
Once again guys thanks
Jon
You see alot of this on Ebay and I'm suprised the honchos don't crack down on it. You see AMD6000 listed as 6Ghz speed and it's definately flase advertising.
