Day 16: 06SEP2011,Tuesday
Cable twisting with help with the Intel Front Panel I/O Connectivity Design Guide, foiling with Mylar tape, and blacking out with good quality electrical tape so that I don't get colours peering through clear sleeving. Good quality tape is sexy
in my world. Also practice soldering and heatshrinking.
Not sure which switch to use for hopefully combining fans and LED lighting, the one on the far left is the original switch that came with the case.
Electrically gifted folks, I need your help.
Image source: Altronics
25W, DPDT~ Dual Pole, Dual Position? Wired: 5V-12V-12V Ground, positions 7V-12V.
9W, DP3T~ Dual Pole, Three Position? Wired: 5V Ground-5V-12V-12V Ground, positions 5V-7V-12V.
15W, DP4T~ Dual Pole, Four Position. Wired NC-5V Ground-5V-12V-12V Ground, positions Off-5V-7V-12V.
5W, 4-way. Wired as simple pass through from molex power.
Not sure how the skipped gaps in the contacts affect connections for the three and four position slide switches.
Devices that will be connected to the switches:
Image source: Silverstone
120mm fans: 1.08W?
180mm fans: 5.4W
Image source: BitFenix
60cm Alchemy Connect LED strips: 7.2W
The current plan
without considerations to wattage limits for the switches, I was thinking combining devices as:
- 3x 180mm case intake fans. 16.2W
- 2x 120mm CPU heatsink fans (Maybe combined with exhaust fan). 2.16W/3.24W?
- 1x 120mm case exhaust fan. 1.08W?
- 2x 60cm LED strips. 14.4W.
