SieB New member Mar 19, 2012 #2 I don't know how much they hold but if you are trying to work out how much coolant you will need i'd get at least 2 liters. I have a 360 rad and I use just under 2 liters, literately just under 2, my res is quite big though.
| raVen | Member Mar 19, 2012 #3 2 liters should be fine unless you will have some CRAZY setup. On my rig I didnt use even more than 1,5 liters and I have 360 and 240 full size rads.
B BKCXb New member Mar 20, 2012 #5 I got a black ice GTS 240 x flow on a corsair H-60, plumbed up with 1/4" hose. My whole loop holds very little coolant, all I used from a liter bottle is around 100mL.
B BKCXb New member Mar 21, 2012 #7 I'm hoping to change this in a few months, 2011 system, WB,Pump,Res, and normal size hose. I'm sure I will need another liter of coolant!!
