Bit of Help
Diablo
Active member
In the near future I am thinking of changing cases. While I like the Xaser, it is simply too big and heavy (it is the aluminium ed.) to haul up to the fourth floor up a tight spiral staircase every eight weeks.
As I have to move it reasonably often and cannot afford to leak test it every time, I am sticking with air cooling.
Can anyone suggest a decent case for my rig? My budget is about £200-£210. I am thinking Lian Li (possibly the A77) so if anyone has any input It'd be welcome.
Can you still get the Super Lanboy? might be worth looking into if theres still some kicking around the interweb.
I thinks its got to be a pretty clean look, mainly because the case has to be hauled up lots of staris and also has to go on the back seats of a car (neither of which are good for the plasticy bits of certain cases). Basically, the minimum of bits which stick out is the best.
Also be best if it were small full tower size (below 60*60 on the side) but below that I might be a bit concerned about the airflow (800watts of heat to dissapate = very hot at times)
