Best timmings and bios
fatty
I need the best timmings and bios for 4 x 512 gskill le in my dfi nf4 sli
I just cant seem to clock it up it will do 200 fsb all day long at 5,2,2,2 2t grrrrrrrrrr I dont think I can get 1t
Dunno m8, im like u with OCZ, im running the same timings @ 2T. would love to be able to use 1T but i cant see it as its down to the chip as far as i know.
It's luck of the draw whether you IMC will actually work at 1t with 4 double sided dimms.... We are talking 1 A64 in a thousand....
If you get 4 x single sided dimms then no problem with 1t....
Mav asked about this same thing at xtremesystems
Yeah the other proble is my ram aint 100% matched I have 437 chips for low voltage and 440 chips for higher voltage although I got a set of la off gollum which has the 437 chips as well so I may mix and match see what happens:D
