A: arctic silver is old now. - Get MX4 or Noctua paste and just stick a pea sized lump in the middle.
B: the antec unit is shit.
C: stock volts means auto which also means they can go up by themselves you have to MANUALLY set the volts.
D: set the bclk to 100 - set the volts to 1.2 and start again from scratch from a multi of 35
When bleeding the system how is the air bubble removed if radiator is closed? Does it end up in the top of the reservoir?
Not so much a watercooling noob as Zalman have some good responsive stuff and my first WC build was the massive Resorator, oldy but goldy!
Stuck to high heavens about what CPU and possible Mosfet solution I should get after watch a second time tinytomlogans COSMOS 2 full review.
I would rather the radiator be a roof fix with fans underneath the rad. and 3 outside the case under the grill SO, What rad. to buy? :huh:
i am not exactly sure what your actual question is lol
maybe create a thread and explain everything with more detail
