B*ttleneck
Horrible CPU bottleneck
4 x TX @1441/1977
5960X @4.5
Valley bench max settings
Compare the scores @1080p and @2160p. In theory you should score 4X higher @1080p.
This is why I don't run this bench @1080p.:D
If you compare the temps of cards at the two resolutions you can see they are hardly working @1080p
1080p
2160p
I'd very much like to see the CPU utilisation graphed through the benchmark before assuming it's the CPU causing the GPUs to have to wait for data. Run CPUZ and GPUZ in the background while rinning the tests again
It's not just Kaap, Many online reviewers *JayzTwoCents as an aexample and even he hates the word bottleneck* who have done multi TX have seen that the CPU is the limiting factor, It's not a conspiracy dude it's just a fact ^_^
Valley is a well known CPU bottleneck
If you run a single TX on it you get 4X the score @1080p as you do @2160p as the fps are not high enough to hit the CPU bottleneck.
@2160p 4 TXs are fine with no CPU bottleneck and no reduction in performance, this rules out the drivers as they will work the same at both resolutions. If you run 4 TXs @1080p this is where we hit the CPU bottleneck.
My definition of Bottleneck : LINK
In simple terms :
If Your GPU is using 3D mode Clocks in games like BF4 - it ain't bottlenecked :P
Smaller utilisation is proof of not having best CPU/GPU combo (or not optimal match), for particular bench/game.
Hope it helps :)
In simple terms :
If Your GPU is using 3D mode Clocks in games like BF4 - it ain't bottleneck :P
Hope it helps :)
Yep, thanks mate ;)
Silly argument this whole "bottleneck" thing, any gpu or cpu will "bottleneck" given the right program or game, the conversation should really be focused on why it's taken this long to get a new API and why the hell are we still using Shader model 5 (2008).
