Drider
[Updated 2016.10.30 v1.1] Project Carbon Candy
So I'm gonna throw up a few pictures of my work in progress at the moment.
I didn't plan on doing a build log for this, as I intended for this just to be a temporary build until the 1080Ti's drop, at which point I'll SLI 2 of them. However as I put more time in, and naturally my perfectionist side comes out, I decided to start snapping pictures along the way.
So here's the rub. If the Man himself TTL stops in my humble thread, and voices he thinks it's a good idea I post up my build log under the projects thread, I'll do so. I've been a long time fan of his YouTube channel, and having him visit my first post on these forums, would be epic. Seeing as how I am here because of his call out for all 1080 owner in his last video (Gainward Reviews), it would be fitting.
A few things to keep in mind if i do the log.
With that said, I own and operate a successful I.T. consultation company, and I'm pretty detailed, so you could expect a pretty good build log. Although this is my first time heating and bending acrylic tube, rest assured I'm a long time water cooler, from back in the days when you had to buy your pumps from tropical fish stores, and hunt through scrapyards for old heater cores for radiators. From looking at the last picture here, you can see I'm diving into the hardest bends I could do as well, by using minimal fittings, (The offset angles are insane!).
Some History:
As I said this was intended to be a temporary build, as the real rig is 3 years in the making.
It started with the purchase of what would be my last case: A CaseLabs Magnum SMA8 To be daubed Project: Oil Spill. A $600.00 case was sure to be the last case I'll ever buy, and at the time I knew I wasn't going to be building the PC itself. It was all about the water cooling and non PC related components. The case is Black powder coated with Gun Metal accenting on certain panels.
I actually was able to get CaseLabs to manufacture a one of a kind top for the case which holds 1 of my 2 560mm (4x140mm) Hardware Labs Black Ice SR1
Why have I waited so long? It's simple. Broadwell-E & Pascal. 3 years ago I knew the budget needed for such an ambitious project, and I timed the launch of the next Enthusiast line accordingly. (Remember, I'm not just building the PC and IT'S components, but the ENTIRE system including the dual loops. It get's pretty costly.) This is why I started with getting every component excluding the PC components first.
So here we are, Broadwell-E in it's glory, but one problem... No 1080Ti's ..
I'm tired of waiting. Build now, and 1080Ti's later, and move to Oil Spill.
So here we go the good stuff:
Intel i7-6850K (No I'm not spending $1700.00 on a processor I'll never utilize, no matter how much I could tell uncle Sam it's a business expense)
ASUS ROG Rampage 5 Edition 10
64GB Corsair Dominator Platinum DDR4-3000
MSI GTX 1080 Seahawk EK X
Samsung SM961 512GB NVMe M.2 PCIe 3.0 x 4
2x Intel 730 Series 480GB 2.5" SSD
EVGA Supernova 1200 P2 Platinum Power Supply
Primochill Praxis WetBench Black/Orange
CableMod Basic Cable Kit (Black/Orange)
EK-Supremacy Clean CSQ - Nickel + Plexi
Swiftech MCP655-PWM 12v Water Pump
Bitspower D5 Mod Pump Top
Bitspower D5 / MCP655 Mod Kit V2 - Black Sparkle Finish
Bitspower Dual / Single D5 Top Upgrade Kit 150
Hardware Labs Black Ice SR-1 420mm (3x140mm)
3x Noiseblocker NB-BlackSilentPro PK-2 140mm x 25mm
Various Bitspower Black Sparkle Enhance Fittings
So I guess the question is, Should I log, or just post up the Completed protect when finished?
I hope you've enjoyed my story
I know an angle is off by about 1 degree. Give me a break, it's the second tube I've ever bent.
The last picture is where I've actually left off for the day. Believe it or not, but this WetBench actually took a lot of modding. It seems every component I have to install requires so cutting/drilling/dremeling of the $200.00 case I just bought. I would not recommend this WetBench to anyone looking to easily setup a test bench. It really could have used a lot more thought... But I'm working with it, and I'm sure I'll be pleased with the end results.
- I've never done a build log before
- This is my first time bending hard tubing
Some History:
