Awesome SLI Bridges
well you might be right (haven't seen them installed anywhere yet), but then again, they will definitely look better than an orange flexible one :)
Vomit brown*
I think they look good, but not very stealthy. Bit of a gimmick product though...
I quite like them to be honest.
For that price, no way though...
The ROG ones are pretty good, and you could easily paint/carbon wrap a normal one if it bothered you that much.
I found a orange/brown/vomit/wahteveryouwannacallit one today and theres no way it's going in my rig like that, so a light coat of black plastic primer fixed it exactly as I wanted, and I tried flexing it and it doesn't crack.
If it was black with GEFORCE GTX green letters and aluminium accents I would be all over that!
It just doesn't match anything or fit in even if it is hella awesome. I think the price is irrelevant if you can afford two 700/titans £20 for a chunk of eye candy to smack between them makes no odds, I didn't think twice about buying back plates for £24 each.
Grhhh.. I want one! It just doesn't... look right, how have they managed to make it not match ACX or reference coolers!
i think it's nice that they did this, but i would appreciate a couple color options because atm these bridges only work for a couple builds.
at last someone has thought about these.
i remember the horrible orange and brown sli bridges that came with my early rigs
I think they look brilliant, it's a shame they're not available in the UK :/ Maybe I could order one sent to my American family, and have them send it here. It's a bit expensive once you've taken that into account, maybe when I've got nothing else in my PC I can think to spend on :)
Edit: Oh, just seen they are on the EU store lol, my bad. I'll pick one up some time :) It says the EVGA logo only lights up with Titans, 780, 770s, so that's a shame, but oh well still looks pretty good.
That is a shame about them only lighting up with a Titan, 780 and 770. I expect someone will manage to mod one to work with older cards in due time.
Perhaps, but obviously it's powered by the graphics cards, so I'd imagine it would be very difficult to do.
EVGA have a little bit of software called 'EVGA LED Control' which you can use to change the brightness of the GEFORCE GTX logo's on 700 series cards and make them temperature/load dependant. They said a long time ago you will also be able to use this to control the SLI bridge so hopefully it will. They must have been working on this for a long time, i'd assume the newer cards have a different SLI bridge standard which allows them to power the bridge LED which probably came from nvidia using those custom illuminated bridges in the press shots.
Just so all know with postage in GBP the bridges work out at £33.97. Meh should be nice, might try a mod if it comes apart easily.
JR
