QuietOne
always shouting
Hi guys
I have this small issue which is really bugging me and see if you guys may be able to help. I recently purchased a 5.1 setup for movies and gaming.
It all works great apart from the annoying little thing that my GPU/Windows is detecting my receiver as a second display. It is currently hooked up to my rig via HDMI from my 980 as you can see here.
(disabled second display for screenshot purposes)
I want to disable the second display and just have audio output from the receiver but if I disable the display it disables the audio device too as you can see here.
I tried mirroring the two displays but unfortunately the receiver doesn't support 2560*1440 and I get resolution error on the receiver display and no audio.
Is there a way to disable the second display and have the receiver as a playback device via HDMI?
Thanks guys.
Thanks guys.
