Asus Z97-Pro Issues
FireCharge
Had some issues today with my Mobo\PSU.
Started the day by getting no BIOS code (I.E. 00), swapped my old PSU which I wanted to do that for a long time, and my CPU with my bro's (4690K for a 4670K) because I thought there was something wrong with that.
Later I managed to get a 15 bios code after swapping the CPU and power supply, so I reset CMOS via battery, which then at long last I managed to get a screen.
Now it crashes every half an hour or so, no matter the load. Temps are fine, running idle or stress testing doesn't matter.
Current system is:
Z97-Pro
4670K @ stock
2x8gb G-Skill RAM
Corsair RM650i
Sounds like a driver compatibility issue or is my mobo just bad?
Thanks!
ATM waiting on Windows 10 to download onto a flash drive, going to try a fresh install to see if that helps.
Edit: Updated BIOS, waiting for crashes
