shambles1980
I realise cinema fps is 24 and referred to that in an earlier post.
Perhaps cinematic is the wrong word to use, but we're just debating semantics really. What I'm trying to get at is that whilst it might not be more cinematic, 30 gives a very different feel to 60, which can be borne of a technical limitation but can also be good. It's hard to debate why I prefer Black Flag at 30 over 60 I prefer the feel, I can't quantify that.
The fact is though that whilst I understand why many would not agree with me, most people are just arguing because obviously a higher number is better to them, be it resolution, framerate etc. All I'm saying is that it's not a universal truth.
you can argue resolutions with me if you like..
my eye sight is not what it once was. and on diferent sized monitors you can tell me 720p with AA looks the same 1080p without AA and i wont argue that.
but frame rates really is about how it feels and its fluidity more than how it looks..
unless you cant keep a constant 60fps up then you can argue lower fps is better for your hardware.
I never had an argument against using lower fps on poor hardware.
Whatever the minimum frame rate your system gets to in the most demanding part of the game should be your constant frame rate IMO. thats why i upgrade so my minimum in any game is not less than 60fps. at 1080p. sometime i have to turn down AA or use lower resolutions. If possible i will use tripple buffer v synk. (i try not to use v-synk though as you get input lag)
so under that premmiss i do believe they should just say consoles cant do 60fps with this game. so we are doing 30..
But instead of that this debate exists.
