You should be able to get a screen for an Inspriron fairly easily, because they are very common. Unfortunately, the only way to find out what sort of screen it is is to open the laptop up and look for the model number written on it. That's usually not very difficult.
CD "repair" kits don't fix scratches, they just grind down the entire surface until it's even with the bottom of the scratch. Not a good idea.
