AMD FX 6100 OC Advice
infexious
Hi!
I'm new to overclocking and was wondering if anyone could give me some advice. I'm looking to OC to gain some more gaming performance. My temps have always seemed pretty high, I'm currently running at 40°C while writing this with nothing else open, and it can get up to around 80 when gaming. I've done some searching online and managed to OC my cpu from 3.3Ghz to 4.0Ghz and (I think) it was stable. I then tried following a couple different guides to take it a step further but my computer wouldn't start up and I had to take the mobo battery out and decided to ask on a forum for some help. I'm happy with 4.0Ghz but I would like to go a little further and OC NorthBridge Frequency, CPU Host Clock Control/CPU Frequency, possibly Memory Clock but I'm not sure how much that will effect gaming performance, HT Link automatically OCs with CPU Frequency and I'm not sure where to put that. Heres a picture of my BIOS settings at default:
Normal CPU Vcore = 1.4125v
Heres a picture of what I've tried to set my BIOS to but then PC fails to boot:
As soon as I OC CPU Frequency from 200Mhz to 250Mhz, the PC fails to boot. I've tried leaving everything else on Auto other than changing CPU Clock Ratio and NorthBridge Frequency to 4000Mhz and 2500Mhz with and without voltage increases, I've tried setting HT Link and Memory Clock as close to default as possible with and without voltage increases, and I've tried PCIE Clock at Auto or 100MHz.
Can anybody tell me what settings I should be using, or what I am doing wrong? Call me an idiot if I'm doing something stupid, no hard feelings.
My system specs are:
Windows 7 64-bit
Gigabyte GA-78LMT-S2P Motherboard
AMD FX 6100 3.3GHz Six Core Processor
Sapphire HD 6870 1GB Graphics Card
2x2GB RAM sticks at 1333Mhz
880W PSU
Standard cooling: 3 case fans + stock CPU and GPU fans
Also, should I be using the BIOS setting "1 Core Per Compute Unit" for more gaming performance, or leaving that at default?
Thank you for reading my first post, and thanks in advance for any help/advice!
80C?!?!?!?! Holy Gawd son! That's about 20C more than the max for these chips. You want to stay under 62C.
By "standard cooling" do you mean youre using your stock heatsink? If so that aint gonna cut it. Youre going to have to invest in something like the Cooler Master Hyper 212 Evo. Those Bulldozer chips suck down a lot of juice and put out a lot of heat.
4.0 isn't that much faster than stock so you shouldn't be hitting 80C while gaming unless you have the voltage cranked to ungodly levels. 4.0 should require no more than 1.375V and more likely itll be 1.32-1.35.
If your voltage is already that low and youre still hitting 80C under load, something else is terribly wrong. Im surprised it doesn't shut off before that.
ok the motherboard GA-78LMT-S2P you have will never be able to supply your cpu the power required to overclock that simple.
