Advice for SB + 570 build
Flanker33
Hey there,
I'll be commencing to buy and assemble my build in a couple of weeks’ time and would like to get some opinions on my build. Should I hold off this build until April and wait for the "all clear, go go go flood the stores" due to the SB problems? I've also never bought from EVGA before, is the quality on par with ASUS?
I also got an ASUS GT 240, should i trash it or use it as a Physx card? I thought the i7 2600 was powerful enough to do Physx vector calculations. There’s a lot of threads recommending mushkin ram but the stores I intend to buy from has none available (or is it because I'm in Australia?).
Will be running Microsoft Office, Cisco, Metro2033, Crysis 2, Bad Company 2 and Battlefield 3.
CoolerMaster RC-692-KKN2 Advanced Bay Tower Gaming Case
Intel Core i7 2600 Processor LGA1155 3.4GHz CPU /
Gigabyte GA-P67A-UD5 P67 Socket 1155
eVGA GTX570 1280Mb PCI Express -<< Thinking of throwing another one in at Christmas if I have money
$425.00 or ASUS for $429 or gigabyte $419
Zalman 1000W Power Supply with Dual Heatpipe
G Skill 8G(2x4G) DDR3 1600Mhz PC12800 ripjaws
RL 9-9-9-24(CL9D-8GBRL)
OCZ 60G Vertex II E Series SSD
(Got an 500GB 7,200 RPM HDD and random DVD drive)
My budget is $2200 AUD
Maybe get a GTX570 from MSI with their Twin Frozer cooler, it will let you get a lot better overclocks, while remaining cooler and quieter.
Power Supply, maybe considering getting a Super Flower Golden Green 1000W or a Corsair HX-850 or HX-1000. Btw, 1000w is a bit overkill.
For the motherboard, perhaps get a MSI P67A-GD55, but I would recommend that you wait until they fix the chipsets for Sandy Bridge motherboards since both the GD55 from MSI and UD5 from Gigabyte only have 2 SATA III ports, so you'll limit future upgrades. Since you have 3 devices that require SATA, I would recommend waiting, but if you really want it now, plug the DVD-ROM into the SATA II
CPU: Get a K processor for overclocking. I would prefer a 2500K over the 2600 honestly. Of course with overclocking you'll need a cooler. The Noctua D14 one of the best coolers out there, and it's cheaper than a lot of it's main competitors.
RAM: Mushkin is available in Australia.
As to where to buy them. I find for Australia http://www.pccasegear.com/index.php offers probably the best prices.
SSD: Get a G.Skill or Mushkin instead of OCZ, they are slightly faster for pretty much the same price.
Here is a screenshot of my recommendation for you. Includes 2 570 in SLI as well =D
