Edge
I'm hoping to get my second ever rig bought and built in January 2014. Here's what I'm aiming for:
Case: NZXT Phantom 530 (white)
Processor: Intel Core i7-4770k
Motherboard: Asus Sabertooth Z87
RAM: 16GB (2x8GB Kit) DDR3 or 4, recommendations please.
GPU: GTX 780 Ti (whatever's best at the time)
Secondary GPU: (to be added later in 2014)
SSD: Kingston HyperX 3k 240gb or OCZ Vertek 4 256GB or Samsung 840 Series Pro 256GB
Primary HDD: WD Caviar Black 1-2TB
Second HDD: WD Caviar Black 1TB secondary from current PC
PSU: Corsair AX850
Firstly, if you could change anything, what would you do? PC is primarily for gaming (5760x1080 @60Ghz, three monitors), with some editing/rendering on the side (my reasoning for going Haswell over Ivy-E).
Secondly, should I be looking at picking up extra fans or something for the Phantom 530? What would you recommend? I'm planning on OC'ing the CPU to hopefully 4-4.3GHz on air cooling.
Finally, the 530 isn't a show-offy as some other cases. I have no knowledge of lighting. Should I pick up some lighting solutions to give it a bit of life, if so, what would you recommend?
Thanks, good to be here! <3
PSU: Corsair AX850
