Eddie long
Member
I have a corsair 780t case with a ek predator, fitted inside the top which has just been replaced by ek after first on leaked ( can't knock there service though ) i was playing with the idea of taking my 2 ml 140mm fans from the front and fitting them to the rad to make a push pull , and then replacing the 2 140mm with 3 120mm to get rid of the gap on the front .
Now the problem , due to the predators make up i will have to cut slots either side of the top rail so the pump/res will sit through them and then refit the vardars above the frame .
so i can then install the ml,s below the rad , dose anyone think i'm being daft or have had this issue before , any comments would be helpful
