Hello again. Here's the deal. I just swapped my Hyper 612 out for an H100i. I was doing 4.4 GHz on my 3770k just fine but never stress tested. After I swapped I ran Prime95 small FFT but ended up getting north of 90C. Then I dialed down to 4.2 then stock clocks; same thing. Next I tried reapplying thermal compound then ran stress test again; same result. I repeated that process a second time with no sign of improvement.
I may still be relatively new to this stuff but I know for a fact a 3770k can easily do 4.6 GHz on an H100i so something is definitely wrong with this picture. I am almost thoroughly convinced its my [crappy] thermal compound since my idle temps are crazy high like high 30s. Tried to spread the stuff when I reapplied the second time and I found that it was hard as a rock and just would not spread like it should.
So any recommendations on better thermal solutions guys? Or am I 'just doing it wrong?' BTW I am using Antec Formula 7 thermal compound (which I used with my Hyper 612 also) and my mobo is Maximus V Formula.
Happy 2013!
XANADV
Happy 2013!
XANADV
